remove lines within a par body
When you hack and slashed imported models, the model keeps a line between section of the model where a portion has been removed and extuded to fill the voids.  some boundaries do not show  up as a line, but some of them show lines of sepration even though it's still one face and solid.  Besides not showing the edge line and etc, can those lines on a face of one body be removed to show a clean surface?
thank you
RE: remove lines within a par body
What is "hack and slash"?  Are you talking drafting section views, assembly (DMU) sectioning, solid body split, what?
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog
I guess that you are talking about vertices?  That would be the closing points for the feature.  A circle will always have 2 points, which become 2 lines when you extrude them.
There's no way to get rid of them, unfortunately. But then again, there's no real need to. If you don't like the way they look, you can just change the render mode. (shading with no edges)
