Connecting Multipule Radios via Cable
Hiya,
This is really outside my area, so I'm hoping you guys can come up trumps for me.
I have a project where I need to connect a number of radios together via cables (for training purposes they are not allowed to actually transmit over air to each other).
Now, I'd be quite happy connecting two together using appropriately rated attenuators between them, but I'm a bit stuck once it gets to more than one. To make matters worse, we have to control the signal level between any two radios independantly.
Now, I've come up with what looks like an extremely complicated design, with fixed attenuators, variable attenuators and ampilfiers wired up in a right old mess. I can't help thinking that there must be an easy way...and you guys must know it!
Any advice appreciated.
RE: Connecting Multipule Radios via Cable
I'm going to put a signal splitter (i.e. power divider) on each unit. Perhaps a 4:1 resistive type. Unused outputs will get a termination. By connecting in different ways I can use either the 6 db splitting loss or the ~25 db port-to-port isolation.
I will connect between the units with cables and a combination of fixed or variable attenuators.
I'm planning on isolating each unit in a metal enclosure to prevent direct radiation around any cables/splitters/attenuators I may have.
Mine is still somewhat a complicated setup. Does anyone else know of some better tricks?
With multiple units, I'd consider simply joining everything together after the attenuators. With that much loss, you do not have to worry about matching (VSWR).
Pay attention to power ratings.
Stay well away from both the noise floor and the damage level and it should work. It's a very wide target.
Standby for further advice from others before you embark on this (just to be safe in case I'm missing something).
It would probably also work just running each radio into a dummy load and putting all the dummy loads into a box together. There's bound to be plenty of leakage especially if you use single shielded coax to connect the load.
It's surprising to me that you would need any amplifiers in your setup. Even a large number of nodes (high splitter loss) the output power from a radio will probably have to be attenuated to simulate a link of more than a meter or two. PathLoss=10*n*log(4*pi*distance/lambda) where n=2 (ideal case).
Peter
I see two simple options if you don't need flat responses over a wide frequency range.
1) buy a small metal box, add bulkhead connectors that can take RF to the inside of the box. On the inside, add a wire to your connector (small antenna, expect poor VSWR). You can add attenuators on the outside to set levels and help VSWR problems once you do some S21 measurements. RF bounces around the box and coupling is very high due to the box even though you may think cutoff waveguide phenomenon would reduce coupling alot.
2) A microstrip/stripline alternative could be printed having a circular shape microstrip circuit. Connectors on the periphery (dozens) with 50 ohm printed lines from the connectors to the center section, print a circle shape where all the 50 ohm lines meet at the center. With this, you could add microstrip variable attenuators in the circuit and use external attenuators on the connectors. This is a poor microwave lens and will have some gain dips if you need very wideband coupling. You could do a similar setup with a group of cables having ends stripped and center conductors and grounds tied together. It's a big mismatch, but you will couple energy to all the other cables.
kch
There are a number of test sets, with 10 to 32 radios per set. The radio frequencies are in the range of 1Mhz to 500Mhz, so a flat response across this range would be preferrable.
I wounder if I could ask VE1BLL and pstuckey to expand on their suggestions a little (as they were the one I think I understood!) in perhaps slightly simpler terms...I did say this was out of my area!
It's one "node" of a 4-radio system.
It would be nice if there was a way of building up to larger systems using a modular approach, but I'm not sure that it is possible.
Anyway, have a peek at the drawing and tell me what you think....
ht
Without checking the math, it should be something like 120dB (but you need to do the math).
Divide by 2 because there will be two attenuators in any path.
You could build a metal box with lots of connectors all joined together. You can only use it WITH the appropriate attenuators.
Matching is NOT (!!!!) an issue when each radio has (for example) a 60dB pad on the antenna connector. That gives each radio a perfect match (120dB retun loss, in theory) no matter what happens past that point.
As mentioned by Brian, you might be able to make the link just using dummy loads at each end. But I saw one example where even 1kW HF wasn't heard a couple of meters away using dummy loads. Some equipment is better shielded than others.
For instance, if I need (simultaneously) 120db between radio A and B, but 100db between A and C, and 150db between B and C, I don't see how I could do it using the method you suggest (but I could easily be missing something!).
Did you take a look at the diagram? What do you think?
I am currently thinking out a similar setup and when I saw your post, I responded with my approach. But, I'm not 100% sure mine is the best either. VE1BLL about connecting everything togehter after the attenuators may work for me.
I gather from your diagram that your application may involve radios with higher power, or that transmit/received at the same time on different frequencies or may involve different antennas for transmit and receive. Hence the need for a circulator and different cable paths for transmit and receive. Is this correct?
The reason I put a circulator in was to stop the "recieved" signal from being re-injected into the "transmit" path - is that the right thing to do?
"120db between radio A and B, but 100db between A and C, and 150db between B and C".
It may be difficult to get 150 dB isolation levels. EMI/RFI leakage considerations for the hardware may be a real challenge, especially at the higher frequencies. Connectors and circuits leak more at higher frequencies.
It may be interesting to do a sanity check with radio's next to each other having cables and loads on their outputs. They may talk to each other thru extraneous leakage and you may have to shield each one separately. That'll change the physical setup and the cost if they are leakers.
kch
Building up to larger is systems is going to be tough if all radios have to see all others. It can be done by adding more splitters, but the plumbing gets messy and you might be better off just using N-way splitters then. Sometimes in simulations like this it is more realistic that not all nodes see each other at the same time, then you could use extra ports on the splitters to bridge between groups (of say 4 nodes each).
In general, I think you are on the right track, make sure your first fixed attenuator can handle the Tx power. It would be helpful if you can provide more details, such as specific frequencies and power levels, and how many nodes will 'see' each other simultaneously.
Peter
There are between 10 and 32 radios per installation that have to "see" each other. Their maximum output power is 100W and various models cover the frequency range 1Mhz to 500Mhz.
Do you think I could do without the circulator altogether?
I just wasn't sure how to stop the transmit signal "feeding back" through the recieve path. I think I need distinct transmit and recieve paths (rather than just connecting everything together in a "lump") in order to be able to control the path loss between any two points independently and simultaneously.
100 W (50 dBm) Tx is alot of power. In general, to use inexpensive components you will want to keep the power well below 1 W. So you could use a high power, fixed 30 dB pad between the radio and the splitter. The signal would then go through a 30 dB pad, 32 way splitter, variable attenuator, 32 way splitter, and a 30 dB pad to get from one radio to the other. This would result in a MINIMUM attenuation of 90 dB (likely a few dB higher). And you could increase the attenuation from there with your variable attenuator. If we look at the path loss equation above (and assume for simplicity that the system antenna gains are 0 dBi - if not adjust the numbers accordingly) then 90 dB path loss corresponds to a range of ~3 km. If you want to simulate smaller path losses (shorter ranges) then you can use a smaller fixed pad, but then the splitter will get more expensive. Werlatone is one company I've dealt with that makes high power splitters. If you can use the larger pad, you can get less expensive splitters from Mini-Circuits.
Peter
Peter
Most receivers have a huge range of acceptable input power levels (in volts, perhaps 0.5uV up to 10mV, square the v for P). That huge receive input range should FAR exceed the most-likely relatively small variation in power output from one transmitter to another.
In other words, if one of your transmitters is a bit higher in output power than the others, then simple put slightly more attenuation on that radio. The extra 3 or 10dB should still be well within the relatively huge acceptable range going into the various receivers.
You could make a matrix and solve for the optimums.
Or simply pick a resonable value for the power at the huge junction point (where everything connects, in the paint can :-] ), maybe 0dBm or something similar.
The key point is that the receivers will have a very wide range of acceptable input levels. Far more than required to level out anything you'll likely run across.
You'll need to do the math and check everything twice before you hit the PTT.
I'm a bit concerned that all the components I come across on the Internet are intended for 0.8-2.0Ghz or more - does anyone do a range for DC to 500Mhz?
VE1BLL - The "dynamic variable element" is indeed just that, its needed to be able to create a required path loss between any two radios at any time to simulate the distance between them, under the control of a PC doing the calculations.
www.pasternack.com always has stock on items, same day shipping when you order.
kch
Your PC would probably have to solve the matrix to distribute the dBs as required. If the matrix can't be solved perfectly then do the best you can.
If you're simulating the real world, then perhaps your system really doesn't have to always be "accurate" (compared to your math model) because the real world has unexpected variations anyway. This depends on your purpose.
Timing might be an issue when several variable need to all change at once (short pulses of too much or too little attenuation as things are updated).
There are many specialize RF path simulators for various specific purposes (especially satellite), but I don't know of any off-hand to meet your requirements. But it's likely there is one out there somewhere.
Good luck, let us know if you run into any problems.
Peter
Just one more question: Do you think it would be possible for me to get a PCB designed that would integrate the functions of the splitter, combiner and variable attenuators into one assembly?
In this sort of scheme, it is common to interrupt the PTT line so that the antenna relays are given time to switch before passing the PTT along to the radio. 50ms is one delay that I've seen used. The transmit load needs to be settled before the RF arrives and remain for a brief period at the trailing end as well.
Such an approach can work with voice radios, but is asking for trouble with anything other than voice. Most data modes aren't expecting an additional delay in the PTT response.
"For instance, if I need (simultaneously)...
120db between A and B,
150db between B and C, ..."
Higgler already noted that these sort of values (150dB) would require pretty good shielding. But, ignoring that excellent point for now and just doing the math, it is very easy to solve the equations for these example numbers:
On A use a 35dB attenuator
On B use a 85dB attenuator
On C use a 65dB attenuator
Join everything together in the middle (huge solder blob).
A+B=35+85=120dB
A+C=35+65=100dB
B+C=85+65=150dB
This simple math ignores the slight mismatch at the three-way junction that would cause the actual end-to-end losses to be slightly different (probably just a bit higher) than the overly-simple calculation indicates. But, it would be relatively simple to adjust things if required.
In practice, you'd use appropriately-big power attenuators on the back of each radio, and then run something like about +10 dBm transmit power (+/- maybe 10dB at your option) into a chassis with all the adjustable and digitally controlled attenuators and 'a huge solder blob' (slight exaggeration) where everything is joined together.
With most voice radios, you're only going to see anything interesting in the last dB before the signal drops out. The radios' AGC will fight all other signal level changes over a very wide range.
You should run a quick experiment to make sure that the radios provide adequate shielding to drop the link when they're all running into dummy loads. Otherwise the whole thing would be a waste of time.
If this is 'just' for training radio operators, then it seems like overkill to provide variable attenuation if you're not also going to simulate all the other stuff found on real over the air links (several types of noise, multipath, etc. etc. etc.).
You shouldn't need circulators (depending on your exact purpose), and you definitely shouldn't need any amplifiers.
And after something like 30dB of loss directly on the back of each radio, you probably don't even need to bother with matching (matched splitters) unless you really need to be more precise than could be achieved with a 'huge solder blob'.
