SW forcing Partial Section View
So I saved my drawing of an assembly that contained some sections on friday. This morning I open it, and it tells me that one of my sections is a partial cut, and will now make that sectaion a partial section. I cant figure out why it does that. I can see in the resulting section that some parts are no longer sectioned. Anyone have any suggestions?
Mike Puckett
Group Leader
Los Angeles/Orange County
Solidworks User Group
RE: SW forcing Partial Section View
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Mike Puckett
Group Leader
http://
Here is the opened version showing section C-C now partial:
h
Mike Puckett
Group Leader
- are all the line segments of the section line still connected?
- what happens if you pull the ends of the C-C line farther away from the ends of the view than you think it needs to go, for example, pull the ends of the lines a couple inches away from the part edges.
Hit ctrlQ a couple times just to make sure.
Good Luck
It is only some of the inner parts which are not being sectioned ... hence the partial section error.
Mike Puckett
Group Leader
i.e. Delete existing section & section line, save, close, re-open, then add section.
BTW, what version of SW?
