Rounding in Equation
Is it possible to round numbers using equations in SW?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Rounding in Equation
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
If you want to round, for example, to x.xx do the following
rouded result = (int(expression * 100+0.5))/100
The int function is available in equations.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
The only problem about the above expession is that, on some criteria, x.5 should round to x-1 instead of x+1.
But the rounding of x.5 to x+1 it's a general accepted rule in engineering.
