Convert a surface body to a solid?
I have imported a closed-knit surface body and want to make it part of the current solit body. Can this be done?
Thanks.
Thanks.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Convert a surface body to a solid?Convert a surface body to a solid?(OP)
Thanks. Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Convert a surface body to a solid?
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Also, the Knit surface feature has an option to Form Solid. You may try editing it and see.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.3 on WinXP SP2
To find the gap, use Tools>Check, run the check and look for "Open Surface" in the results list. If you click on that, it will show you where it is open. There are a lot of techniques to close open surfaces, but the easiest is to RMB on an open edge and select "Select open loop", then go to Insert>Surface>Fill, and hit the Merge switch at the bottom, and if this will close off the surface, you can also hit the "Try to form solid" (gotta love the optimism).
good luck,
matt
Good tip on finding and repairing open surfaces.
Jason
