Element numbering for Ekill
Is it possible to find out the element numbers associated with a particular volume, for example in a series of ten volumes, the element numbers assigned to elements making up volume number 3. I can find the number of elements with the list command just not the numbering which ANSYS has applied to the elements.
This is for a subsequent Ekill command to represent material removal in drilling operations.
Thanks!
Thanks!
RE: Element numbering for Ekill
just issue:
CODE
eslv,s
elist,all
Alex
