Distance between butt weld
Hi
Is it any restriction in codes that required minimum distance between butt welded for ASME 31.3 code.If any what is the rules?.
RE: Distance between butt weld
Review SecIX QW-250.
Talk to a good Welding Eng.as it could be dependent on process.
If this is for proxmity of joints to one another there could be other concerns--again the Welding Eng. could help you.
If you are refering to the proximity of one butt weld to another then do a search on "Proximity of welds" as this has been asked before.
