Palm Pilot based vibration analyzer
I have a need for an inexpensive vibration analyzer, preferably hand-held. Seems to me the utility of inexpensive Palm Pilots could be leveraged as cheap CPU/Display combinations. Ultimately I need average displacent data (inches-per-second) at a specific phase angle. I can marry a circuit design to affix to a Palm Pilot. Can anyone refer me to app notes with ready-to-rock circuits?
RE: Palm Pilot based vibration analyzer
Due to the requirement of providing sensor signal conditioning and suitable battery life it requires the use of a module. We have chosen to work upon the HandSpring Visor platform and it's standard expansion module. It will support multiple languages and run as an additional application to the various Palm applications already loaded.
Phase will not be included initially so balancing will not be available. It will be possible to load a balancing algorithm for manual entry and to utilize the Visor to perform the calculations.
Pricing (w/Visor included) will be in the in the $700 - $800 USD range. For customers with a PDA they can simply purchase the expansion module with accel and Palm application for about $500 USD. It is designed primarily as a field service troubleshootng device, not a PdM data collector. It will be available at the secure e-commerce site: www.reliabilitydirect.com
www.imv.co.jp
This is similar to the one posted about the SKF instrument.
They have an instrument now on the market called a Cardvibro VM 2001. It uses a Visor as it's PDA. Looks OK with specs. takes overalls, time waveform and 1600 line FFTs. Worth loking at. But I'd stick to dedicated instruments for now.
It looks like a nice tool. Too bad that the price has tripled from the original estimate.
Gunnar
Cheers and Happy Holidays, DG
