Arch-pipe as Pond Outlet?
Has anybody tried to model an arch pipe or anything other than the standard circular or rectagular as a culvert outlet?  If so, I'd sure like to find out how you did it.
RE: Arch-pipe as Pond Outlet?
If you open the culvert screen in HydroCAD and click the Help button you'll get some suggestions for modeling an arch pipe.
Granny:
As psmart points out, the help system suggests using the overall pipe dimensions with a 0.9 multiplier for arch pipe or 0.8 for eliptical pipe.
However, when I am dealing with finicky regulators, I use a "Special User Defined" outlet and supply data from HY-8.
A custom device will work fine - as long as you're not dealing with variable tailwater.  But if the flow is tailwater-dependent, then you'll need to use one of the standard outlet devices, whose equations can handle the extra variable.
