cut extrude along a path?
I have a thin tube that will fit into a larger solid peice. But the catch is that the tube needs to be bent at a radius through the solid. I am trying to do a cut extrude through the solid to accomodate this tube.
It seems like it should be a fairly easy thing to do. If anyone knows, it will be greatly appreciated.
RE: cut extrude along a path?
Would a cut sweep be better
Make a CL 3Dsketch thru the solid where you want the tube, a sketch of OD and ID of tube, extrude along the path.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Thank you both.
