Holes .TXT info needed
Dear Board members,
On a cilinder part i need a external thread of 1x16TPI
I need info to fill in the Holes.TXT file in solid edge program.
A sample (in a different size)
.0600;.0465;.0447;#0-80 UNF
For the 1x16TPI i need the:
Nominal        diameter
Internal minor diameter
External minor diameter
Tread type
As i am a European,i am not familiar with theys measurements
Thanks Anthony
RE: Holes .TXT info needed
I have only these data at hand that does match:
16-UN: Unified Thread Series
Description   Nominal   Drill     TPI   Pitch
1" - 16-UN     1,000     0.937       16     1,587
Seems to be a special thread ...
dy
Thanks for the info
Nominal             diameter = 1.000" ?
Internal minor      diameter = 0.937" ?
External minor      diameter = ....." ?
Tread  type         1x16 TPI ?
External minor ?  , i need  they's to fill in the Holes.TEXT file
Anthony
Have you tried looking up the information in Machinery's Handbook?
Ben Loosli
Sr IS Technologist
L-3 Communications
Hi Ben,
Living in Amsterdam and dont have excess to the Machinery's Handbook.
Can i find it online somewhere ?
thanks ,
Anthony
if you do not have a need for these dimensions otherwise
just put in
External minor      diameter = 0.937
Or in Holes.TXT
1.0000;  0.937;  0.937; 1-16 UN
SE will work with that, I've just done it myself with
2 BA threads for which I could not get the dimensions
You may correct them later on.
dY
I made a mistake in my first posting:
the pitch is 0.0625  I forgot to convert it from mm to
inches
The corediameter is approx. D - 1.2226 * pitch (UNF/UNC)
so 0.937 can be used as a ballpark figure with UN
dY
altnickee,
Have a look at this link - it shows the thread form of UN threads.
There is a series of UN threads called 'Constant Pitch', of which 16 tpi is one of the series.
Quote:
Constant Pitch Series
The UN series provides a comprehensive range of diameter pitch combinations where the Coarse, Fine, and Extra-Fine series do not satisfy the requirement of the design. They are available with 4, 6, 8, 12, 16, 20, 28 and 32 threads per inch.
http://www.answers.com/topic/unified-thread-standard
altnickee,
Here's a handy web page.  Has some Machinery's Handbook pages and much more.  Virtual Machine Shop www.jjjtrain.com/vms/index.html
Gov
