vane flow anemometer vs airflow chamber (flow bench)
Which would give higher accuracy in measuring volumetric airflow rate - a vane flow meter with a flow hood or an airflow chamber designed as per AMCA 210-99?
http://www .bis.fm/pr oducts/Air flow_Devel opments_Ai rcone_Flow _Hoods.asp
http://www
RE: vane flow anemometer vs airflow chamber (flow bench)
If you're seeing >10% difference between the chamber and flow hood, it may be your setup. Are you accounting for the additional pressure drop caused by the flow hood?
ko (www.ecooling.biz)
