guide to paving and drainage
I am starting on a project where I'll be introduced to paving and drainage. The little that I have learned so far seems pretty standard and conducive for a step-by-step guide. For example, Step 1. Locate critical tie-in points such as streets, driveways, etc. 2. Create drainage area map. 3. Etc. Obviously, each step would described in detail.
Does such a step-by-step 'guide to paving and drainage' exist?
RE: guide to paving and drainage
Good luck.
