migration V5R15 -> V5R16
Is there a recommended procedure to move from one release increment to another (like, V5R15 -> V5R16)?
For instance, does one have to uninstall the older version completely, and then install the new? Is it possible to retain the user settings, under this scenario?
Can the two versions be installed side-by-side (ie to test functionality for a while)?
Thanks!
Thanks!
RE: migration V5R15 -> V5R16
If you want to use R16, forget about R15. Your CATSettings will have to be recreated (there is XML dump that makes things "easier").
If you want to use R15 and R16 on the same machine, no problemo, just make sure to use different CATEnv directories, env files and a different folders for settings.
Cheers
This is only true if you follow the steps outlined by Excalibur. Otherwise, the first time you enter the new version, your old settings will be wiped out. (overridden by the "default" version - which is always the last one installed) And not segregating can cause problems with settings being present for non-existent funtionality between versions.
This is all set up when you install. Just be careful, read the prompts during installation, and keep it separated. It's really quite easy. I have versions 12-15 currently installed.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
