tip relief angle of gear shaper
I do not know much about terms of gear in English. Sorry.
What's the tip relief angle of gear shaper for? machining requirment. right. one of them.
and one more, after shaper resharpenning, keep the root of gear unchanged. right? if you agree, then,
theoretically, the angle will not be always the same. so the relief cone is not straight, it is protruding after x=0 section.
I need your opinion, thanks
