Using fnval in for loop SLOW
Hello all,
I am writing a code for some data analysis, and I have to fit a spline to the local max and min points in data.  To fit the spline I am using
fun1 = csape(x1,y1)
fun2 = csape(x2,y2)
I then have to find the mean of the two splines. For that I use the following code.  (I did not want to use a for loop! I know this is not efficient coding in MATLab.)
for j=1:n
    m(j) = (funval(time(j),fun1) + funval(time(j),fun2))/2;
end
I originally tried this
m(1:n) = (funval(time(1:n),fun1) + funval(time(1:n),fun2))/2
MATLab did not like this.  Is there anyway to do this without running a for loop.  In some cases n > 20000, and I will have to repeat this 1000 times per case. And I might have 15 cases, and I don't want to have to wait two days for my results.  So I guess I am asking is there a way to do this without using a for loop, or is there a way that I can get my sline to be defined by an array and not a function?  Any ideas would be greatly appreciated.  The fnval takes a while on its own, put it in a for loop and it takes forever.
jason m.
"Education is what remains after one has forgotten everything he learned in school."  Albert Einstein
RE: Using fnval in for loop SLOW
I figured it out.  You can use fnval in the manner which I said could not be done.
ie..
m(1:n) = fnval(t(1:n),f1) + fnval(t(1:n),f2)
not sure what I was doing wrong before, but this does work, and my time to compute on cycle went from 2.4sec to .35sec.
jason m.
