Developed unfolded shape of a spherical triangle
Dear All,
i am having a problem of drawing the unfolded elevation of a spherical triangle.
I want to cut a shape glass which later on i will gravity bend it to form a spherical triangle having a radius of 1123mm.  The spherical triangle will form almost quarter of a hemi-sphere. Height of the spherical triangle measured from the top to the base is 1082mm.
Please help.
Thanks a lot.
Marisse
RE: Developed unfolded shape of a spherical triangle
Really I do not know how to do it .
But your question was done by the early topographer or catographers when they try to represent the map of the continents, the made a lot of trick to do it.
Are you asking how to develop a pattern  for a slice of a spere like an orange segment cut across the middle?
B.E.
I don't think this shape can be unfolded in a true form.  The closest I could get was a quarter of a hemisphere as a surface in SketchUp and unfolded in Pepakura "orange peel" fashion.  I'd attached a picture but I can't in this forum.
I've made this before in real life but you need to deform the metal sheet.  We pressed a 16 gauge flat sheet supported on the end of a tube around a metal sphere under a press on that occasion, then cut out the section we wanted.
If you take a flat plate and shape it into a sphere (or other double-curved shapes), it requires that the plate be stretched or contracted in various places to form that shape.  It can't be formed by simply bending a flat plate.
A similar problem arises in forming steel- as in water tower sections.  There, the solution is partly trial and error.
In other words, there's not a simple solution.
