toolbox hardware...want to use metric
I want to spec in a metric pan head but can't get to the file through toolbox. My toolbox is on the network and configured correctly. (my toolbox.ini file is correct and I am pointing to the network location in "File Locations"). I can add the folder to my design library (see link htt p://multit erra.moolo ad.com/fil e.php?file =files/170 206/114020 4392/ansi+ metric.jpg) but when you drag parts from the design library, you don't get the option to configure the size of the pan head...just the default size shows up in the assembly.
I need to find the correct procedure for placing the ANSI METRIC folder in the Tollbox along with ANSI INCH (see link).
Can anyone tell me how to do this?
Anyone know what I am doing wrong?
regards,
dsgnr1
regards,
dsgnr1
RE: toolbox hardware...want to use metric
tools, options, sys options,data options, edit standards data, configure data
I had ansi metric disabled.
regards,
dsgnr1
Any time you have a problem just ... figure it out your self.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
