Maintenance Access Path for Box Culverts
Hi. I'm working on a flood control project whick calls for the replacement of five tidegate culverts with a triple cell box culvert. The owner wants a maintenance access path, one on each side of the ditch, for seasonal cleaning of the proposed RBC.
The issue here is that the site is phragmite-infested, and this is huge part of the reason why the cleaning crew can't even get access to the pipes. Due to this problematic situation, the owner wants an access path that is maintenance-free, i.e., phragmite-retardant.
One engineer suggested using a geotextile overlaid by inorganic fill and tacked down on the sides with pressure treated timber. I have been to sites where the geotextile is hard to locate due to plant overgrowth, so I am soliciting improved ideas. I would really appreciate if anyone could share their knowledge and/or experiences on successful projects on maintenance free access paths to culverts. Thanks in advance.
RE: Maintenance Access Path for Box Culverts
http://www.cement.org/water/dams_sc.asp
