available fault current
I am being asked to calculate, then mark(identify) 4 different locations, on a customers electrical infrastructure.  Very simple installation. Small 3 phase service provided by the power company, then feeding several loads thruout the companies property.
 Is there software/info available where you can input known information, at a certain put along the line, and it will tell you this?
 Just a little help pointing me in the right direction Guys.
HP
RE: available fault current
Do a search on this site.
Mike
I use software from SKM.  I've also used EDSA and ETAP
Thank you Ron, I will check those out.
HP
I use EasyPower from ESA.
