WINCH CAPACITY CALCULATION
I AM TRYING TO CALCULATE THE LINE PULL OF A WINCH DRIVEN BY
A HYDRAULIC MOTOR WITH A OUTPUT TORQUE OF 4022NM AND A DRUM
DIAMETER OF 300MM WHAT IN KGS WOULD THE WINCH LIFT
RE: WINCH CAPACITY CALCULATION
F=Torque/Effective Winch Radius
Assuming direct drive and on gear loss
To calculate this properly,
4022 X 90% (mechanical efficiency assumed) divided by effective radius of capstan (in metres) 0.15 divided by acceleration due to gravity 9.81 mtrs/sec squared
Therefore 4022 x 90% / .15 / 9.81 = 2459.94 KG
how to calculate the amount of cable held in a winch?
seajob
Hi leep
While I agree with boo1 and here to chill, your capacity to lift will be limited by the tensile strength of the cable, also bear in mind as the cable wraps onto the winch drum the torque requirement to lift will also increase.
Can you provide more details like speed of lift, cable strength etc, remember also that when starting to lift the cable as to accelerate the load from rest.
regards desertfox
desertfox
You may not get a response from leep, as I note that OP date was Dec 19 2001, and leep has not visited the site since then!
seajob
Try 2 x π x mean radius x number of turns
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
Hi johnwm
Thanks I hadn't noticed the date.
regards desertfox
Thanks Johnwm for answering my question.
