How to create a sculptured surface from a cloud of points in space?
I am completely new at ABAQUS so please be patient. I have a "cloud" of points in space(about 50 points). The points were retrieved using a coordinate measurement machine. The machine took these points from a part of irregular curvature/surface. I am trying to model the original part using these points along with ABAQUS. Thus far I have inserted all 50 points in ABAQUS. How do I connect the points to form a sculptured/curved surface? Also how would I extend this surface once developed?
RE: How to create a sculptured surface from a cloud of points in space?
I assume that you have imported the points into ABAQUS/CAE? I don't have a lot of experience with CAE myself, but I don't think it has the surfacing tools that you would need to create the geometry.
It would probably be better to take the points into a CAD program so that you can generate the surface, then import the surface into CAE for meshing.
Martin
Thanks for your help. I have took your advice. I have been trying to create a surface using unigraphics. I am also a first time user of unigraphics. I have tried just about evrything within the documentation of the program. It seems I get very close to createing the surface and then I cannot complete the last two /three steps. Do you have any insight on how to do this on unigraphics NX3. Also can a model completed in NX3 be usable within ABAQUS
Cheers
paul
No experience of UG I'm afraid, only Pro/E and Solidworks
You might be better asking in the UG forum http://www.eng-tips.com/threadminder.cfm?pid=561
As for getting the surface into CAE, you could just export either an ACIS (.sat) or IGS file out of UG and import that into CAE for meshing.
Martin
