Roof Top Equipment Platform Live Load
When providing a maintenance platform for a rooftop HVAC unit, what is the proper live load for this platform? The platform that I have in mind would be a steel frame supported by posts a couple feet above the roof with an open grating walking surface(In this case it would be added to an existing roof). The walkway would be used for equipment maintenance. The IBC LL of 60psf for "walkways and platforms" seems very high when considering the platform load as a whole applied to the existing roof. I could see using a localized load of 100psf for sizing the grating, but what is the realistic load on the whole platform when determining post loads applied to the roof structure below?
I'm thinking that the code determined "minimum roof live load" (not snow load) in the neighborhood of 20 psf would apply to the platform as well. The snow load would also be applied to the roof around and under the platfrom. What do you think?
-JCali
-JCali
RE: Roof Top Equipment Platform Live Load
-JCali
40 psf doesn't make sense to me in some cases... For instance, if the equipment is sitting directly on the roof, you could use the minimum roof live load to cover the load from maintenance personnel. In many cases the roof LL is 20 psf or less. But as soon as you raise the same piece of equipment onto a platform, the maintenance LL increases to 40 PSF. It's the same maintenance person working on the eqpt whether it's on the roof or on a platform, yet the design load is different. Locally, I'd design the grating for at least 100 psf, but would want to use a much smaller LL to determine post loads applied to the roof structure.
Thoughts?
-JC
