How do I update an Add-in
I have made an add-in for Excel with functions specific to our company. I am updating this add-in on a weekly basis. I am currently going to each workstation to copy the new version to the add-in folder.
How can I have the add-in automatically update for each work station?
Can I store the add-in on the server?
Can I move the default location for add-ins?
Any suggestions are appreciated (especially the convoluted or bizarre).
RE: How do I update an Add-in
Yes you can keep the add-in on a network server, and setup each machine to look there. Browse for the addin in Tools/Addins, then answer "no" when Excel asks to copy the addin to the addin folder. You can also check the registry key where Excel stores the installed addins:
HKEY_CURRENT_USER\Software\Microsoft\Office\9.0\Excel\Options\
(replace the 9.0 by your Office version, probably 11.0) in the entries named OPEN= , OPEN1=, etc.
Alternatively, you can set the alternate startup file location to some place on your network. That will allow you to add new add-ins as you develop them. This is specified under Tools/Options/General.
Cheers,
Joerd
Thanks.
I had gone through that process before but I did not click "No". I didn't know that it was that simple.
I did this at my previous company.  It works well, but be aware that everyone will have to have excel closed when you want to update the add-in.  If even one person has Excel open, you will not be able to overwrite the add-in file on the network.
Panars, I just did an overwrite with some simple code included in the add-in for a test.
It was successful even though 2 other people are using Excel with the add-in active.
We are running Excel version 11.
Whoever logs in first gets the ability to save changes. This is usually me but sometimes not. I have now experienced the read-only message after updating the VBA code.
Brad.
Can you give read-only access to the add-in to everybody else, while maintaining read-write access to yourself?
Cheers,
Joerd
I tried to do that with some VBA in the workbook object but I haven't been able to make it work. It's a low priority project.
