Newbie Question...
Newbie Question...
Newbie Question...
Im trying to get two different text sizes in one entity..like "section a-a" where the a-a is bigger than the section text..
RE: Newbie Question...
Double click, and select them independently for text height adjustment.
If I'm understanding you correctly, you want to go from this:
To this:
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog
Forgot to mention - once you select the text, (after double clicking) you just need to use the pull down box for size, in the "dimension properties" icon bar.
I guess you probably figured that, though...
