How to obtain mass and stiffness matrices with Abaqus
i am working with Abaqus and I am trying to obtain the mass and stiffness matrices of my structure. I know the command to use in the .inp file but I have problems using the "ELSET" keyword ... Could someone help me ?
Thanks a lot ;)
Alain
RE: How to obtain mass and stiffness matrices with Abaqus
hi Alain
If I read you right, you need to specify an elset name on the *ELEMENT MATRIX OUTPUT card.  You can define the elset using the *ELSET card and put the elements you need into that.  Check in the ABAQUS keywords reference - should tell you what you need to know.
Martin
The problem is that actually I can't found what is "elset" linked with...
I can't find in the Abaqus help file where "eleset" needs to be specified.
Alain
*ELSET is just a convenient way of grouping elemnts so that you can operate on them.  It can be defined at either the part or instance level - have a look at *ELSET in the keyword reference.  You should define a line like this;
*ELSET, ELSET=myelset
1,2,3,.....
Then, when you define the matrix output;
*ELEMENT MATRIX OUTPUT, ELSET=myelset
will output the matrices for the elements in myelset.
Martin
Martin
Ok, thanks a lot !
Alain
