Concentrated loads on basement retaining walls
I am in the process of designing a two story residence over a basement. There are numerous large concentrated loads on the basement wall. Retaining wall calculations consider all pressures and axial loads acting on a 1 foot strip of the wall to determine vertical steel design and foundation design. With the concentrated loads included in the design, the foundation seems to be extremely over-designed. My question is as follows: Can the larger concentrated loads utilize a 45 degree projection through the longitudinal axis of the wall down to the continuous footing? This would spread the load across a larger area of the footing.
RE: Concentrated loads on basement retaining walls
