Offset Section View jog lines
This is from a thread in the Solidworks forum called "Section jog makes a solid line in section view", thread5559-147246 . Basically the question is: do you show the "jog" lines on an Offset Section View? To show an example of this, I found a PDF on the web, h ttp://www. coe.uncc.e du/~gkwatk in/ETGR110 3/week_13_ slides.pdf on page 7.
Note that the jog lines are not shown in the offset section. It was pointed out in the Solidworks forum that it was drawn in AutoCAD, I say it isn't an AutoCAD way of doing things, rather ANSI standards. What do current ANSI or ASME standards say is the correct way of showing the jog lines? Do you not show them or not?
Flores
Solidworks 2006
Flores
Solidworks 2006
RE: Offset Section View jog lines
I am feeling a wave of nostalgia for the good old days of pencils and drafting boards when I could present my drawings whatever way I damn well pleased. These days, we are all at the mercy of whatever is it our CAD software wants to do. It is possible in SolidWorks to hide the bend lines. I do not know about the other 3D CAD packages.
My rather old Genium manual does not show the bend lines, but it does not say not to do them.
Standard or no standard, the bend lines make the discontinuities obvious. The drawing I am working on at the moment would be confusing without them.
JHG
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
