Pattern vs. Hole wizard for hole series?
Just something I thought about on the drive in this morning. If you have a steel plate that needs to have a series of (20) holes, are there any advantages to using a pattern (linear or circular) over the hole wizard or vise versa?
Thanks in advance,
Thanks in advance,
I even dream in Configurations.....
Config 1 - Brunette
Config 2 - Redhead
Config 3 - Blonde
RE: Pattern vs. Hole wizard for hole series?
As for which is best ... IMO a feature pattern is always better than a sketch pattern. Whether the seed feature is created with regular geometry or with the HW is immaterial.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Bloodclot
Config 1 - Brunette
Config 2 - Redhead
Config 3 - Blonde
Whichever way you go, the more holes in the pattern, the slower the rebuild time.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Therefore, I vote with CBL
I use sketch-driven patterns with no problems. I use the hole wizard for the first hole, then create a point sketch to drive the pattern of holes. The same pattern feature will be used in my assembly to populate the holes with screws.
Yanceman
ps: nice dream config, too bad two of the three are suppressed! lol... :)
Thanks for your input and it makes good sense. Something I will keep in mind for the next time I need to do it.
Bloodclot
I will have to try to dream in sub-assemblies next time :)
Config 1 - Brunette
Config 2 - Redhead
Config 3 - Blonde
Now if I switch on the Animation add-in ... adjust the lighting ... set the limit mates ... OHHH WOW!!!
LOL! That was great!
Yanceman
