Can macro code to copy a trendline equation be written?
What I want to do is utilize a polynomial curve fit equation (of specified formatting) from a chart. The relatively small amount of basic input data is not well-suited to using lookups and interpolations directly.
It's easy enough to manually copy this information from within the chart object and paste it into a target cell using menus and the mouse, but I'd like to get a subroutine to do this. Thus far, I can't seem to get any code learned from mouse manipulation or keystrokes to copy the contents of the trendline equation box to the clipboard or wherever. If it matters, I have Excel 97 SR-1 and Microsoft Windows 98 4.10.2222 A .
Downstream of the copy/paste procedure that I'm trying to automate, 'Right' and 'Mid' functions separate the individual coefficients, thus allowing the trendline equation that pastes as text to be rewritten as a useable cell formula.
Norm
Norm
RE: Can macro code to copy a trendline equation be written?
Please look at the following posting & responses in thread770-23296 regarding the linest function and its capabilities.
While i do use the trendline feature, I also use the linest function to determine the equation constants as well.
i hope this helps.
good luck!
-pmover
Norm
=LINEST(INDIRECT(O7),INDIRECT(N7)^{4,3,2,1},TRUE),
where N7 and O7 are the string formulae
="N9:N"&8+N6 and ="O9:O"&8+N6,
for the X and Y data in columns N and O respectively, where N6 is a COUNT of the number of input pairs entered in N9:Oxx. The data must be on consecutive rows (starting in row 9 in this instance) but it need not fill up the entire COUNT range of rows.
=COUNT(N9:Nxx)
Norm
