Bonding and suspending eps blocks 2
I've been working on a project in which I am encapsulating 6" square X 6' blocks of eps in concrete. Due to the low s.g. of the 1# eps vs. the high (2.4)s.g. of the cement I've been having some difficulties. I'm curious, does anyone know of an adhesive I can use that would allow me to mount plastic or metal plates to the foam core that would withstand these pressures? The finished product is 10" square by 6'6" long. Also is there an adhesive you would recommend for bonding the scraps together so I could recycle the 2' chunks? I'm currently casting the parts in an open top collapsible form and using I-bolts connected to T-nuts thru crossmembers to hold the foam down and in the proper position/orientation. On the foam core I've glued mounting brackets that the I-bolts connect to. I haven't been able to find a decent adhesive that is both strong enough to hold the core in place, and also non-reactive with the eps itself. I've previously posted this in the materials section by mistake, and I've had a couple of good suggestions. I'm interested in something that will both be rapid setting and adapted to an automatic process in the future. We will be producing approx. 50,000 units in the next 9 months.
RE: Bonding and suspending eps blocks 2
Keith Mort
Franklin International
Technical Specialist
http://www.franklininternational.com
