CGR with multiple solids, Show/Hide just one solid
I have several CGR's that when combined make a very large assembly. All of the CGRs that make up this assembly have many solids in them and I need to Hide/Show the solids individually. Is there any easy way that I can select an indivual solid or does V5 see them as one combined solid because they are in the same CGR file?
Thanks in advance.
Thanks in advance.
RE: CGR with multiple solids, Show/Hide just one solid
We do have this problem sometimes... Only way i correct this is rebuild CGR from CATPart or .model then manually relink those CGR to Product...
