Microbial corrosion
Microbial corrosion
Friends, what's the best to confirm bacterial (microbial) corrosion? We have a specific case of perforations identified on corrosion coupon at the receiver end of Oil line. As we are suspecting MIC, what would be the best option to confirm that, other than taking the sample for micro-analytical studies.
RE: Microbial corrosion
Here are two companies that supply field testing kits to verify MIC.
http://www.mic-testing.com/
http://www.bti-labs.com
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
