Generate A Chamfer To An Edge inside a Bellville Washer
I have an irregular shaped column that has had the top SWEEP cut.
The SWEEP cut was at an angle so the radii across the top constantly changes.
I have been unable to get a chamfer, either by the Chamfer or SWEEP CUT commands.
RE: Generate A Chamfer To An Edge inside a Bellville Washer
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Sorry for the delay. Had to learn to post on WEB. Please try this.
http
11991
Also, it looks like your chamfer is coming all the way to the inner vertical surface--that's likely your reason for failure. I'd consider sweeping a cut around your part instead of using a chamfer like that.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Let me try to answer both remarks.
1.Yes, I get an error message to the effect that "could not build chamfer due to geometry conditions".
2. I have tried at different times ALL 4 outside edges and at other times ALL 4 inside corners but not all 8 at one time.
3. I need it to come all the way to the inner surface.
4. I tried what I thought was a Sweep. I am not sure it was as it did not work.
5. I have uploaded another picture that may or may not help to clear things up.
Thank you both for helping!
http:
You can make a sweep work if you use the innermost edge as your path (create a composite curve or something for a sweep path) and a shape somewhat like the state of Nevada for a profile such that your vertical edge is coincident with your path and your angle downward forms your cut chamfer.
Should work well without the bumps seen in your latest image.
Jeff Mowry
