Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This has been the MOST helpful forum that I have been a part of and I want to say thank you. The tips, tricks and helpful advice that you all contribute to have been lifesavers in many instances..."
Geography
jezequel (Mechanical)
15 Feb 06 2:58
Does anybody nkow if its possible to change the default units to mm? I think when it was installed they were set to imperial, and now all the design accelerator tools are in inches...
PeterCharles (Mechanical)
17 Feb 06 15:25
IV 10 Help
Tools - Document settings - Units
Sets the default units system and dimension precision for the active model file or template.
Note: To change the default units system applied when you create new files, change the default units in the templates that you use to create files.
When you installed Autodesk Inventor, you specified a units system that is automatically assigned to all new files. You can change the automatically assigned units by editing the templates used to create new files, or replacing the templates with your own.
Note: Templates are in the Autodesk\Inventor<version>\Templates folder. Any part, assembly, or drawing file becomes a template if you save it in the Templates folder or any of its subfolders.
Hope this helps.
Close Box
Join Eng-Tips® Today!
Join Us             Close
