Difference between geometrical set and part body
I m fairly new to Catia. I want to know the difference between a geometrical set and a part body.
Thanks and cheers
RE: Difference between geometrical set and part body
A Geometric Set is the container for wireframe geometry.  A Part Body is the container for the Solid.  The Geometric Set is not heirarchical or order dependant.  The Part Body is.
That is, if you are not using Hybrid Design or Ordered Geoemtric Sets.
