Pressure Rise in Pipe
I need to brush up on my thermodynamics a little bit:
A pipe is full of styrene (a volume of 45 gallons) and the temperature is raised from 0 F to 80 F.  What is the pressure rise in the pipe?
Is it just the difference in vapor pressure of styrene between the two temperatures?
Thanks.
RE: Pressure Rise in Pipe
The mass remains the same and the density decreases with temperature increases so the volume or pressure must increase.  I don't know the rate of change in density of styrene, but with water the pressure change in a water-filled system is very close to 100 psi per 1F.  If there is a small void space or steam space then the rate of pressure change is orders of magnitude less (it is a steam-table calculation then).
David
Thanks for the reply.  It seems the change in density is about .2 lbs/ft^3 per change in degrees C.  Any help with the calculations?  Is there a specific correlation?
Thanks.
Assuming the fluid is a liquid, the pressure rise will be tremendous.  You should have a pressure relief system if there is any way the pipe could be blocked off.
Tony Miller
Cornerstone Engineering Group, p.c.
http://www.cegpc.com
RJB32482,
Take a look at thread124-83163 by 25362.
Good luck,
Latexman
and thread135-85389.
Have you used the Search feature on this site yet?
Good luck,
Latexman
thread135-115061 is helpful too.
Of course, if you just use a 3/4" PSV with no calculations, this has no practical value, but it does cure the thirst for knowledge, and knowledge is POWER!
Good luck,
Latexman
