curves from drawing to part
Is there a way to get curves from catdrawing to catpart? We are getting data in 2D autocad drawing and then need to export curves for tool shop. Any ideas
RE: curves from drawing to part
You need to save as .dxf, and copy and paste the geometry (pick the whole view) from the dxf into a sketch.  From there, you will need to adjust the scale.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog
itsmyjob (Mechanical)
Select the view in catdrawing and COPY. then open new CATPart and Past. you will get a sketch...
Eric N.
We found that this will work from dwg files also
