move part in product
hi,
I know that you can use manipulation and compass to move parts around in a product, but is there a way to move the part in x,y, or z direction by certain amount.
For example, move a part in y direction by 20mm or something like that.
thank you .
thank you .
RE: move part in product
You will need to align the compass the same as you would normally, and pay attention to the vectors, based on your alignment.
You can use the compass the same in both parts and assemblies.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
In the centre of the compass there is a red box.
Put your cursor over it and then hit the right hand mouse button.
Then select edit from the menu.
Now you can translate and rotate anyway u like.
