Vertical Seismic Component QE
How do I calculate the vertical seismic component QE per IBC? The UBC had a formula used to calculate this component but I can't find one in the IBC.
(I'm looking at a building that is 6 stories with concrete slab floors and masonry bearing/shear walls. I'm doing a spot check on a couple of walls on the ground floor, so it's just a 'quick' hand calc for now - I won't be modeling the building just yet.)
RE: Vertical Seismic Component QE
thread176-98527
thread487-121459
