Epoxy Grout vs Non-Shrink Cement Based Grout
We have 4 gas turbines for our cogen project. Now under construction phase. Our spec is epoxy grout. The eqpt supplier recommend non-shrink cement based grout.
Any opinion?
NORZUL
Any opinion?
NORZUL
RE: Epoxy Grout vs Non-Shrink Cement Based Grout
Non-shrink grout is very susceptible to variations in mixing, whereas epoxy grouts are relatively foolproof.
Yes, the non-shrink grout will be more brittle and lower strength than the epoxy grout (in general).
Use the epoxy if cost not an issue.
I think that if epoxy grout is specified and cost is not an issue then better to go with epoxy grout. If cost was an issue then there are many cementitious grouts on the market with well tested performance records that would make them worthy of consideration. Personally I would only prefer epoxy if their particular adhesive bonding qualities were required.
Is it common to epoxy grout only the soleplate or the entire baseplate?
Based on our previous experiences, we normally grout the entire baseplate skid but now the supplier recommend only to grout the soleplate or the anchor bolt area.
Any advise?
