ACAD LT Image Attach
Is it just me, or is it true that you CANNOT attach an image file with LT at all. I just downloaded ACAD LT 2006 for demo (I use ACAD 2005 at work) and I found that I cannot attach an image file. Any shortcuts here from anyone?
RE: ACAD LT Image Attach
That's all I found as well. You can rename, use a new file, etc, but can't attach... another way for Autodesk to force "Real ACAD" on everyone.
I suggest throwing LT in the garbage and getting the full version. If you're working in Civil I recommend Civil 3D (w/Land Desktop/Civil Design Companion). LT lacks the functionality available in the other packages.
Or you can just send me your projects and let me draft them up for you. smile
