How to calculate centre distance of spur gears?
Hi everybody,
I have the following gear application:
1)Pinion data
Module = 3.5
Z1=14
Pressure angle = 20°
x1(Addendum correction factor)= 0.228
Diametral pitch = 49 mm
2)Gearwheel data
Module = 3.5
Z2=286
x2(Addendum correction factor)= 0
Diametral pitch = 1001 mm
I need to calculate the distance between axis to complete my project. Can Somebody give me the formulas to do it (or bibliography to search)?
Thank you in advance,
Carlos
1)Pinion data
Module = 3.5
Z1=14
2)Gearwheel data
Module = 3.5
Z2=286
Carlos
RE: How to calculate centre distance of spur gears?
(Z1+z2/(pd*cos(y)*2)
where z1 and z2 are no. of teeth
pd is diametral pitch
cos(y) is cosine of helix angle.
Ravi
http://www.gearsandbearings.com
The " Diametral Pitch" mentioned is actually the Standard pitch Diameter. DP is used in Imperial Unit Gears.
would be 1/2 the pitch diameters
plus .228 x 3.5
i.e. (pd1 + pd2)/2 plus xm x module.
or (286 + 14)x 3.5/2 = 525mm
plus .228 x 3.5 = plus = .798
yields 525.798mm and
has an operating pressure angle
of 21.1234
You can start out with the 21.1234
pressure angle and see if the other
formulas work.
