NPN Transistor & welcom
Hello everyone. New here and I wanted to say Hi first of all.
2ND: Working with zener diode to bias an NPN transistor as a power supply. Believe the transistor is used to increase current to drive circuit.
At normal input voltage (30Vdc) everything works fine. At lowever voltages (20Vdc) the circuit does not work. I "believe" the reduced input is reducing my Ib, therefore current gain is less.
Does the current gain Hfe vary with input voltage and current's? I see the spec sheet rates gain at Ic =100mA. My Ic (Ie) is more around 7.5mA under good conditions and drops to 2.2mA when not working.
any ideas or explanation of how current gain is determined or varies under different inputs?
thanks,
JS
RE: NPN Transistor & welcom
TTFN
I've contacted to manufacture and waiting to hear back. another question: What techniques could I use to measure the currents (Ib, Ic, Ie) I've used my Fluke meter and measured Ib = ~7uA and Ic=Ie = 7mA. I contacted Fluke to ask about accurance because the signal is phone simulator (19Hz ringing)
Fluke said meter worked to 20Hz and I should measure another way.
any ideas?
Jon
By just messing about with your supply voltage and looking at the results on a scope you can answer all your questions and probably learn a lot quickly!
TTFN
Looks like my "load" requires more current than power supply can produce at the lower input voltages.
not for a class. Sort of a nick /nack project for myself and to learn more about transistors also. Learning in real world is differnt than my classes at school. all the "given" specs and information didn't vary in school like they are now.
Welcome to the real world of electronics, where things are not always as they seem; the physics always wins! It looks like you are off to a good start so keep exploring!
