DOWNWARD WATER FLOW THRU PERFORATED PLATE
I AM PRESENTLY DESIGNING A HYDRO COOLER WHICH REQUIRES A WATER DISTRIBUTION SYSTEM, IS THERE A CALCULATOR OR FORMULA AVAILABLE TO GIVE ME THE FOLLOWING?
1) DESIRED WATER FLOW - 10, 15, OR 20 GPM
2) WATER HEAD ABOVE PERFORATED PLATE 4" TO 5"
I NEED TO CALCULATE DIA. & SPACING ON HOLES TO GIVE ABOVE MENTIONED PARAMETERS
RE: DOWNWARD WATER FLOW THRU PERFORATED PLATE
StoneCold
If so, download the free sampler from here:
http://www.hydrocad.net/
It is very user friendly, it sounds like vertical or horizontal orifices are what you want to model. Try that.
Remember, amateurs built the ark...professionals built the Titanic. -Steve
http://www.iperf.org/pressure.htm
