Drilled Footing / Caissons
Are there any computer programs for drilled footing/caissons? If so, what are the names of the software.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Drilled Footing / Caissons
http://www.dot.state.fl.us/Structures/proglib.htm
Then download "Drilled Shaft Design for Sign and Signal Structures, v1.1,” This will require MathCAD to run it.
It is free compliments of state of Florida and its taxpayers that I represent.
Use at your own risk. You must be familiar with the theory and practical aspects.
Lutfi
No joke- if you are drilling piles/piers or caissons, that implies you are putting some structure of value on some piece of property. Foundations are the only part of the building that is nearly impossible to fix if you screw up.
For lateral type conditions (like what Lutfi responds to) I would suggest that there aren't enough programs out there.
