Hole Wizard
Hole Wizard
Hole Wizard
Is it possible to change any values in Hole Wizard and make it as default (in the any .mdb files or something like it)?
RE: Hole Wizard
CorBlimeyLimey, thank you for your help!
But is it possible to export updated Hole Wizard Holes data from one computer to another?
RE: Hole Wizard
If you are NOT using SW Toolbox;
You cannot export the changes, but you can copy the relevant file (C:\Program Files\Common Files\Solidworks Data\lang\English\SWBrowser.mdb) to another computer.
If you ARE using Toolbox;
You can point each computer to use the same file using the "C:\Program Files\SolidWorks\Toolbox\Toolbox.ini" file.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Hole Wizard
CorBlimeyLimey,
thanks again I've found it.
