tunnel lining penetration
A project we are working on requires a penetration through a existing concrete tunnel lining. The tunnel is in rock we are drilling a vertical shaft to the required elevation. the problem is that there is approx 20' of head above the tunnel. How can we limit the amount of water flowing into the tunnel?
RE: tunnel lining penetration
Richard A. Cornelius, P.E.
WWW.amlinereast.com
