Multi Depth Flap (Wing)
I have a contoured flap which needs variable depths at various section. I have the main surface. I tried skecthing the milled surfaces at plane normal to this surface, projected it on that surface. Tried using split, but gave me an error.
Is there any easy way???
RE: Multi Depth Flap (Wing)
Why bother projecting a curve, when you have a plane to use for your split?
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog
