tree disappeared
tree disappeared
I tried to reduce the size of the tree with the scroll. At least it disappeared. Please help me if you know what to do!
(F3 shows as active, but nothig can be seen on the screen.)
RE: tree disappeared
You will have the XYZ axis at the right bottom corner of the display area. You can do a mouse click on it so that the geometry grays out. Now you can scroll back the tree using the mouse. Click the same axis after the tree is visible to get back the grayed out geometry.
Hope this works out.
Ashvanth
